phase 1 rear end mods?!
Car  Renault Clio sport 172
hi im concidering changing the rear lights on my phase 1 172 to the ones off the phase 2. does anyone know if the bumper and boot lid will fit too?! or if its a good or bad idea altogether?!
thanks Andy.:S
Do you mean fitting ph2 bootlid and bumper? Or will the ph2 liights fit with the ph1 bootlid and bumper. Either way I think it all fits. As ph1 peeps often change to ph2 rear bumpers.
Make sure its the right colour !!!-
the PH2 colours are different-
Steve
They're the same car essentially.
Lights are the same size - you just need to swap some wires over on the connector block. Reaaaaal simple !
Bootlid and other body panels (past the first 6 inches) are identical ph1>2.
Bumpers are different (obviously ;) ).
yeah lights look simple enough. just wondered whether the bootlid fitted basically because i quite like the renault badge in the centre and the bumper is definitely better! cheers for the warning on the colour difference though!
You Sir, are quite incorrect :rasp:
A 1.2 ? .:
A real Sport ! .:
I'm actually thinking of putting a phase 2 rear badge on to lose the boot key
