Project OEM+ Chavbox. Alot of Pictures
  Petrol Blue 182.
Re: Project OEM Chavbox. Alot of Pictures
Nice! whats the steering wheel btw? where did you get it from?
  Mk2 Escort
Corsica rep from Rally Design. Not quite the OMP quality but at 50notes its a bargain. Do a leather one (what i have) Or a swede one too.
Really nice saxo that love the colour :cool: i didnt no what to expect with the chavbox title lol but i like it alot nicely done
As said not all saxo's are chavy but thats how they get thought of, couple of pics of the 1 i owned great little car
  Mk2 Escort
View attachment 53809View attachment 53810
I do think the title is misleading but thats my humour towards it. You old saxo looks smart, mk1 too. Even better
  Mk2 Escort
Righty o
Lets bump this bad boy up.....
As mentioned my friend who did my MOT said that the headgasket is starting to leak and oil is mixing with the water.
This was quite a big spanner in the works tbh as i was planning on getting the car into the bodyshop this month.
Having a car that works is a higher priority than it looking nice.
Im hoping to have the car's bodywork done by fcs but its going to be very tight.
Anyway, the car is off tommorow for a week away
Having the full works as it were:
Head off and stripped
Head dipped and skimmed
Valves re ground in with new seals
New head bolts
new head gasket
inlet & exhaust gasket's
Oil change
Coolant change
Clean out all the pipes etc
Cam belt
Tensioner
Water pump
For the price im paying i could well of put a 16v lump in there but its not what this car is about. Its plently fast for me atm and with all this maintenance it should drive spot on again.
My ideal world would have been to pop a ph1 cam in and raceland mani at the same time but funds are tight.
Thanks alot for looking. hopefully have some updates in the form of a decat later in the week.
  Disastra Coupe
The R lump is still plenty fun enough dude. In mine i never once thought 'damn, i wish it was quicker'.
It's all about the twisty's anyway :)
  Mk2 Escort
I knew you would understand Chip. Aslong as the car is done for fcs then the time between that and trax ill be whoring the bay for trax
  Mk2 Escort
Right, its been a while people. (4 months to be more accurate).
Quick update with what has been happening. As mentioned earlier the head has had a full rebuild and the car is running sweet as ever (only covered 1500 miles since the beginning of April!)
Theres a lil bit of progress so ill try and keep this short;
After the rebuild i got a decat pipe and fully heat wrapped it (not running any heat shields so it helps), and coupled this with group n hard rubber mounts.
This pipe sounds the nuts!!!! I am totally in love with the sound it makes. I have no video clips at the moment but im sure Fletcher, wonkystripedbandit, autoba and originalboyracer can back me up in this.
When i got the car in the air to fit the pipe i saw the drivers front arch was caked in oil. All the wheel / brakes / arch were dripping. The metal clip that hold the CV boot on and snapped open and the boot had slipped down the driveshaft. With a quick bodge it was off to a mates garage for a whole new driveshaft.
At this point FCS was drawing ever closer and even thought i keep my paint as clean as i can it had developed a fair bit of laquer peel on the front bumper over its life. So i booked it into a local bodyshop to get it sorted, however i got carried away and it got booked in for every panel to have some work done (bar the roof)!
It was done in time for FCS (just).....
The bodyshop work was as follows:
All parking dents removed from doors
Dents in wings removed
Dents in boot removed
Removed rear badges
Sprayed both doors / wings / rear quarters / boot / spoiler / bonnet / front bumper
All black trims sprayed in satin (more oem look, textured satin spray)
Also fitted carbon fog blanks, red snap off boss bolts just before FCS.
The car was a mission to get clean in the few days i had it before fcs but turned out to be all worth it, resulting in me picking up the FCS Special award on the Saxperience stand
Pics of fcs:
my ugly mug with my trophy
My speakers had been playign up for some time so next on my list was some sort of upgrade. My requirements were;
Had to be lightweight
Direct replacements to fit behind the standard speaker grille.
They had to be full range speakers (not comps) as i didn't want to mess around mounting a tweeter.
Had to be good enough to not need an amp to get any decent sound out of them. Don't want to go to the trouble of adding more weight with an amp etc.
I opted for some SPL Dynamic speakers and cannot rate them highly enough, build quality is top notch as is sound quality.
New:
vs Old:
Oops
Just bought a PugSport Grp N Lower fork bush for the car and soon to be joined by a full set of VibraTechnics Fast Road engine mounts which should help transform the car.
Thats progress up to date i think, here is a current spec list and some pics to end....
Spec:
Engine
1600 8V BlackTop Engine
Fully rebuilt head (Acid dip / skim / all new gaskets and seals etc)
Oil Catch Tank
Fully heat wrapped Supersprint Exhaust (decat)
Kam Racing motorsport exhaust mounts.
Transmission
Standard VTR Box
GE Quickshift
Brakes
Wilwood Midilite 4Pots
Braided hoses
Drilled & Grooved Discs
Rally Design Poly E pads
Suspension
Apex Springs & Dampers (35mm)
Pugsport Group N Topmounts
OMP Lower Brace
OMP Upper Brace
Powerflex ARB Bushes
Powerflex Wishbone Bushes
Powerflex Beam Bushes
Fully rebuilt rear beam
New Trackrod ends / droplinks / etc
Nyloc Hubnuts
Wheels
15" Anthracite Speedline Turinis
Exterior
Full Respray in original colour (Crimson)
Carbon Fog Blanks
Smoothed rear badges
Smooth boot release
Bumpstrips sprayed in textured satin black
Carbon Chevrons
Carbon Mirror caps
Heko Wind deflectors
Recessed front plate / Pressed metal rear plate
Smoked indicators
CitroenSport side badges
"HackSaw" edition ariel ;)
Detailed!
Interior
Mint vtr seats
Alpine Headunit
Spl Speakers (removed rear speakers and wiring)
Sound deadening removed under carpet
Quaife black nylon gearknob
RallyDesign Dished wheel
OMP Boss
ProBolt red aluminium bolts
B&G Snap off boss
Thats about it. Going through every section there is something on the "todo" list so it looks like ill be busy over the next few months etc.
Thanks for reading
Enjoy
Sam
Coby.
  XC60-R.......V40-R
Looks great.... Nice to see one being done properly :)
  Mk2 Escort
Thanks fletcher. On the look out for a very nice manifold at the moment but the one i want is rare as fook.
Tom
  i3
Why is it called Project OEM? What is OEM about it?
Or is it that it was OEM and now isnt?
  Mk2 Escort
Is that the CitroenSport one?
Belive so, the pugsport one for the 8v i think. Or the gmc 8v one seem to be very good. May have to settle with a cheap one though
Thats awesome
really like that
Thanks alot
Yes buddy, i cant change the thread title. But it started more towards the oem route but i cant call 4pots oem lol. Heading towards a more purposeful route with the car now but i like to do things to a high standard thats all.
  Mk5 golf gti
More like 'the way citroen should of made it'
  Mk2 Escort
Don't normally like Saxos myself but that does look really smart, nice work!
your car always looks smart
Thanks alot for the comments guys.
The car is going down a more performance orientated route now, as i have caught the trackday bug now (and realising the car has only done 1500 miles since april!). Along the lines of a single seat and harness. However i will keep the inside as good as the outside with a sprayed floor and braided hoses throughout.
I know people say it will ruin the clean look of the outside but i think i can make it work.
  Mk2 Escort
Vibra-Technics Fast Road Ecu Mount
Vibra-Technics Fast Road Gearbox Mount
Vibra-Technics Lower mount
Pugsport GrpN lower fork bush
Should do me nicely
  Mk2 Escort
Wow, lets bump this up!
There is a alot of progress behind the scenes at the moment, just keeping it all under wraps for now. Will throw in a few teaser pics though;
Ariel Removed;
Pimp Bolts, who can guess what they are for?
Crappy updates ftmfw
  Mk2 Escort
Ha got you on that one fletch.
Have also just purchased some p-clips, braided hose and a riv nut gun (awesome tool!)
All coming together now ;)
