what is a rs tuner??
I'm after one at the moment.
My knowledge of them is limited and my explanation will be crap so i'll not bother trying to explain.
Simply, it's a box that allows you to remap your car yourself, either using the standard maps or you can buy a custom one from henk.
It also works as a fault code reader.
It won't give you huge peak hp gains but mid range will be improved a lot. Certainly a noticeable difference.
Apparently smoothes out the Idle aswell
Certainly will.
You'll never get the gains that you'd see from a custom map, but the flexibility makes it worthwhile. You can play around with maps, pops and bangs maps etc (if henk has released a 182 one yet?), if you don't like it, map it again.
Awesome piece of kit just used one myself now car is completely different and much better to drive. Problem is they are like hens teeth so keep your eyes peeled.
make sure you do a search mate. They have been covered soooooooooooo much. Have a look regarding what's required, ie.if you buy a second hand one, you need a licence to unlock it. things like that really. They are good for the money though.
