LED side lights
I used to have them.
They weren't that good imo.
2 rows of 6 LED's.
Got smoked ones on now, and they look much better.
I've got some cheap blue ones that I bought when I was at the Top Gear show... they look a bit chavy but pretty cool tbh
I've got some SMD ones off eBay I think they're 9 SMD and cost £4.99 delivered which was good. They've been in for a couple of weeks and I've not had any problems so far. I'm not fussed by the 'no sidelights' craze aslong as the bulb colours match on the xenon's and the sidelights it looks ok.
SMD LEDs are they way. Mine have lasted over a year. Normal LEDs fry because of the heat from the headlights.
agreed i have the SMD lamps and they are much better than LED my LED's lasted a week and one of them went out i also installed them correctly too cheap and nasty aint the way yo!
How do you fit these? Have I got to unplug the main beam bulbs before I can get at them? Font want to have the bumper off etc to get a good look. Cheers
Take off the rubber cover
Pull out the white plug with the wires going into it
Pull the old bulb out of the holder it's in
Push the new SMD bulb into it's place (Might take a bit of positioning and force)
Once it's in turn your sidelights on to see if it works
If it doesn't then turn it round and test again
Push back through the hole it came out of
Refit rubber cover
Them 8smd ones look really nice!
Found 25smd bulbs on ebay, which ones are worth getting 8 or 25 smd?
