Bilstein shocks are used by h&r, which knock within a few months.
FK Konigsports, use Koni shocks alround also. Been great on track for me, can give you lots of 'lows' and are fully adjustable which you cant do with the others.
Oh and there the best part of a £100 cheaper!
So with the FK coilover kit you can adjust both ride height and the damper stiffness too? Koni do make a coilover kit but for every model of Clio bar the Sport
shut the f**k up! Why do Prodrive, Aston, Lambo, Maseratti, Mazda, Subaru, Mitsbishi etc use them? You'll be telling me next Pi springs and V-maxx coilovers are "wicked" - behave Danny
there's members on here that have ran H&R's for 5years now without a rebuild (nurburgring boys) - try that with your v-maxx
Bilstein - one of the best suspensions IN THE WORLD
do the bilsteins have adjustable damping? do I need adjustable damping?! I will be using the car primarily on track.
Who supplies the bilsteins for top dowwah that aren't 'tards?
The bilsteins cannot be adjusted manually. But the good news is they have fancy internals. The valving has a relatively high damping rate for low velocity inputs and a low flow restriction for high velocity inputs. This will give a firm ride with reduced impact from harsh bumps.
Who cares? They go low enough . Slam any car too much and you might aswell stick some gaz on there. 30/40Mm is enough
Thanks for the information!
For me 40mm is enough.
The Billies are the coilovers for me, that's for shure!!
Let ship them to the Netherlands!
they do go lower, 20-25mm is only what's allowed for the TUV German test, they'll go down 40-60mm no problem
I wrote to Kam Racing and several other shop, but i still don't know how low you can go with Billies B14 on the Clio B?!
Bistein says:
20-25mm.
KamRacing says:
They will go lower, but they didn't tell me how low.
Who can help me? I like to buy the Bilstein but not when they lower the car only 25mm.
But we have the height on our website which you had read already, hense why you emailed in the first place...![]()
