ESP+SERV+ABS Lights on, Nothing on RS-Tuner, New sensor
aucky
Car  N
Evening all..
A fault appeared a week ago..
ESP + SERV + ABS lights are constantly on.
After a read around the forum it looks like a brake pedal position sensor. So I bought a new one from renault and fitted it.
After switching the car on/off a few times the fault cleared, happy days. The next time I drove the car it came back and has stayed on ever since.
Rs Tuner shows no fault codes either, and I haven't had any braking issues whilst driving..
Any more ideas?
RSTuner wont do break system faults, take it to any local garage that has a decent snap on diag tool. Should only cost about £25.
Steering angle sensor only make the ESP + service light come on if its a 182. Does not seem to affect the functionality of ABS.
So id say this is something else. Put a clip on it and find out
£65 for the privilege isn't it?
Had the same on mine at it was a snagged wire in the steering column causing the fuse to blow on the ABS. Worth checking the fuses.
steering angle sensor? where is tht cus i get my serv and esp light come on after driving a while
Its sits right behind he steeringwheel. If you take away the plastic cover over the steering column you can see it closest to the steering wheel. Usually you manage to f*ck it up when changing to an aftermarket steering wheel (I did it too)
