Gets in the way if you're fitting brake cooling ducts.
Ah right i see. Is there no way it could be just relocated?
Anyone got the part number for this? Might just have to get a sodding new one so the light goes away!![]()
May as well get rid of it, it's only there for bollox EU regulations I think.
Tried a resistor today as well across the two prongs of the electrical connection, again, no difference. Still have the engine management light on.
Out of interest why does everyone bother plugging the cable from the inlet manifold? Why not just leave it plugged in with the electrical connection?
Yes it is. If it's been removed or not plugged in then you will get a light. If removing I normally just leave the purge valve plugged in.sorry for unearthing old topic. Is it possible that I have a check engine by a carbon canister valve?
Computer shows an error carbon canister control valve.
