xenons still not fixed
Car  clio 182 sport
ok had the bumper of recently swapped parts around with parts of the side that workes theres nothing wrong with the bulb or the small black power pack on the side that doesnt work. im cheesed of with the fact that i had the bumper of and its still not sorted i really dont want to pay someone to sort it as its so easy to remove the bumper. am i right in saying that the only other thing it could be is the ballast can you get second hand ones any advice on my next move thanks.
Swap the black packs on rear of bulb and the silver ballast attached to headlight
Check fuse also
its not the fuse i know jcc cant believe i didnt check the ballast if i remember right me and my m8 thought it looked a bit tricky so we didnt bother is it easy to remove
It has 2/3 small screws holding it in place on the headlight then it simply pulls off, piece of piss.
thanks for the replys jcc so with this problem its normally the bulb ballast or ignitor-power pack am i right.
hi hopey-182 my xenons stopped working few weeks ago, my problem was the relay which is under the dash on passenger footwell have look see if its come loose hope this helps.
lee
thanks lee checked this b4 will do again wish it was that easy it woudnt be so bad if you took bumper of once and sorted but its a clart on keep taking it of as a process of elimination.
Don't keep taking the bumper off. Everyone say's you need to yet i swapped my Xenon bulb's this weekend and managed to do it without undoing a single bolt, wasn't even that hard tbf, just a little fiddly.
no worrys hope u find the problem
lee
lee
where would this relay be on a lhd car?, had a look behind the glovebox , but nothing there, and no room for anything at the rear of the pedals.
I have the same problem rhd xenon not working.
