Any decent car mechanics in Norwich area?
Jack it up, crack the nuts .. pull it off carefully .. job done. Reverse the procedure on the other car... job done.
Might want a bit of heat on the ones joining to the cat mind... drown them the night before and the morning too in PlusGas/penetrating fluid... What's the problem ?
I'm an utter noob with a spanner (I hate spannering/being under cars) and I took my Yozza off and fitted the original Renault one all by myself in about 20 mins.
Damnit !
Basically guys I'm ment to be swapping my standard exhaust system for his yozza cat back
He has sent me a picture from where the centre section joins his sport cat..
The centre section has been cut and a smaller diameter bit of piping has been welded on so that the centre section will fit the cat.
Here is a picture so you can see what I mean
