How do i remove battery?
Austin-182
Car  182
Can anyone help guys, how on earth do i remove the battery to get it to fit? Does the bracket to the ecu need to come off? And what is this tubing in the picture?
That is the drain pipe. There is a clamp that goes through the hole to the right of the mount take that off then it will come out.
Haha, its ok lads im sorted now.i got it out but couldnt get the new one in, i moved the ecu bracket to have the room
Surely putting the new one in is the reverse of taking the old one out unless the new battery is a different size?
Lol the new one is bigger yes, i cant bolt the airbox in place as the battery is bigger so the air feed going into the filter wont move any further for me to bolt the airbox down though
Why did you buy a bigger battery?
Might have been less confusing if you'd said this at the start.
