Lunatic mk7 fester
Car  Mk5 Ibiza Cupra
Just saw this on Auto Trader, wow!
http://www.autotrader.co.uk/classified/advert/201139417632464
2 Doors, Manual, Hatchback, Petrol, Green. Mk7 fiesta 3dr shell with a modified 4+4 sierra cosworth floor pan The body kit is from old school engineering with a rear spoiler from mountune, The engine is a field motorsport built 2.0 litre 200 block, 6 longstudded, Garrett GT30 roller bearing turbo, matched ported and polished head, double valve springs,BD16 inlet and outlet cams, RS500 inlet, 8 green injectors, p8 ecu with pectel piggy back board running coil conversion an anti lag, cosworth pistons, H section con rods, WRC oil injectors, flowed block, big wing sump with baffle plate, air tec intercooler, pace radiator, remote oil filter with mocal oil cooler, custom exhaust, external waste gate,909 engine bay loom, 2 Bosch 044 fuel pumps running billet fuel rails. And much more TRANSMISSION Six paddle clutch with hydraulic set up, front diff 909 thick wall ATB, rear diff 909,gearbox is a Dennis osbarne dog box 5 speed standard ration 4+4 box, uprated drive shafts. SUSPENSION Gaz gold coilovers,adjustable top mounts, adjustable ARBs and track control arms, poly bushes front and back rear subframe has steel WRC body mounts. BRAKES Ap racing sixpots with 362mm discs at the front and 300mm reyland discs/bells/and spacers at the rear with braided brake lines through out the car with a hydraulic hand brake snd a bias pedal box.NOT ENOUGH SPACE,PLS CALL, PX possible, £55,000
for that money you could buy a car that's not 567% Chav
EDIT: And still have change to buy a 1.2 clio and do all the "usual CS refinements" to keep the chav dream alive
Lets all say what we're 'all' thinking here and stop beating around the bush
"Needz lowz"
"Needz stance"
"needs turinis"
"M3"
etc.
Like the car, but £55k... For 55k I would want much nicer seats for starters....
Ill have a FRS and some change I think
Insane, just like the price. Would anybody seriously have that over a GTR? No thanks.
This is the problem with a lot of these type of cars,the owners actually want their money back once they've done the mods.
Such a waste of money.so much better out there.
