Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
engine itself is near enough the same. Might have to swap the end housings off the head to get the right temp sensor (if one is plastic and one metal) aswell as changing the inlet for the appropriate throttle type
Easy swap. Like danny said end housings. No need to change the manifold, just change the throttle body (it will fit). VVT never came on clio unill clio 3 in 06. It was on 2003 megane 2 and scenic 2 though.
capable of running slightly wilder cams. Newer engines make a little bit more power.
On the flip side, the VVT pulleys on the K4M are very bad for becoming noisy, and you'll have a nightmare trying to get an ECU that will run it to work in your car unless you go for standalone. Stay non VVT, it's an easier life
