Clio 182
Plenty of threads kicking about on this topic but none seem to have the same set of symptoms as my '04 182:
Engine light is on (solid, not flickering)
Car starts perfect, first time, every time
Idle a bit lumpy but perhaps not unusal for these cars
If driving from cold, within a few hundred metres car judders and loses all power (misfire??)*
Pull over and idle for a minute and it drives perfect again
MPG still seems fairly good (mid 30's for short journeys)
*as I use the same route to work daily I always end up losing power going up a steep hill, I assume this is coincidence and not relevant to the fault?
Faults codes:
P0130 -- Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0135 -- Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
I guess my question is: do I go ahead and replace the lambda sensor(s), or are they just showing up error codes because of something else. Should I change the coil pack first (especially as it's cheaper), or even TDC? If it was one of these at fault would they throw up their own fault codes too?
Any advice appreciated.
Faults codes:
