Playing downloaded films on my Xbox 360?
Gally
Easy enough to do?
Do copied dvds work?
I have a quite a few films on the laptop and have the Xbox for dvds was hoping I could watch some of them on the Xbox.
I'm a bit of a tech noob. To a point anyway.
Nickson
Unsure if copied DVD's work.
But any films will play through the Xbox if you have them on an external hard drive, memory stick or some network storage device.
I cannot remember the formats that it supports, but definitely .AVI
Gally
I've no idea streaming wise guys apart from a cable from laptop to tv.
Avi. Got it. Hmm will have a look how to put stuff on from a Usb stick.
Nickson
Put stuff on from a USB stick? :eek:
Just drag any films you want to watch on to a USB stick.
Plug that into the 360, go to Video player and select 'External Storage'. It should then list the films you have on the storage device.
Select one and away you go! :)
Gally
Lols. I meant xbox. That sounds better than streaming I think although that sounds very cool.
  Monaro VXR
Have mine set up so it integrates with Media Centre. So all my films show up with the artwork, synopsis etc streamed over the network.
Works well.
Gally
I wish someone would set that up for me.
I have laptop - wifi - router - xbox wired to router! Noob!
  Bus w**ker
I stream directly from my NAS to my 360 through the default Video "App" thing. No media centre, no f**king about. DLNA FTW.
Nickson
Still, why would you want to have your laptop/PC turned on to watch a film you can store on a memory stick and simply plug into the 360?
Makes no sense! ;)
Same here!
Get's a bit laggy when more than one person watch a film from the NAS though :dapprove:
  Goliath I
I put all my films, series etc... onto an external hard drive. Saves space on the laptop and just plug directly into 360 to play. Easy Peasy
  Bus w**ker
Max the RAM out on the NAS and make sure it's a gigabit wired connect to each streaming device, that should sort it.
  Monaro VXR
Have a DLNA server running too, for connection straight to the bedroom TV. However since the Xbox can support media centre with all the benefits that it brings I use that on the xbox.
  1.8 Civic EX
Same here, saves having to have both the laptop and xbox on at the same time too, it realy is the simplest way to do it.
Rob
Films will play perfectly off of USB kev, but only in pony .avi
I'm a .mkv man myself, I've never had any real faith in the xbox for streaming and now I've got a mac I doubt it works at all? (am I right here)
.avi's aren't awful though, so crack on you simpleton.
Cookie
Tversity <3
Mine streams mkv's, tends to rinse the PC though (re-encoding on the fly)
  Mk1 MX-5 next summer
Mate gave me 500GB worth of films and a few TV series on a Hard drive.
Plugged the USB into the fucker and boom they're all there and work.
Mint!
Clart
I've never had a problem streaming video using the normal video app. How the hell do u copy stuff onto the xbox hard drive though. I've got 200 Gb spare but can't figure out how to copy to it.
Cookie
Is it actually any good cookie monster?
i.e through my xbox?
Yes, it's awesome
I don't use a pretty front end or anything, it just displays a list of folders that I specified on TVersity and plays whatever I like
Just works :D
