Laptop wont start!
Car  RB 182
Just thought I'd post this here on the off chance that someone might be able to help.
I have an old Samsung R40 Plus laptop. A few days ago it froze while playing a game and it wouldn't respond to anything so I shut it down. Ever since then it wont boot up. When I turn it on it gets to the Samsung screen and just freezes. I've managed to get into the bios about 2 times but it freezes after about 2 seconds. I've tried putting a new hard drive in it and thats not working. Any ideas as to what it could be?
If it's freezing in the bios it wont be the HDD, that's possibly relating to the RAM or the processor and or motherboard failure.
RAM's a solid shout, specially if you have some spare :)
Just look in the back, will be a small cover with a Phillips screw in it I would imagine. Will probably say ram or memory on it. Flip that out, take out 1 of the modules and replace the cover. Try and start it up, if there is still no joy replace it and take out the other module.
I opened up the cover that said memory on it yesterday, and there seemed to be 3 different bits in there, but none of them seemed like they would come out easily?
I'd start by trying to discharge any static build up in it.
Remove the battery and power supply then hold the power button down for 10-15 secs. Put back together and try it.
looking at that photo, it seems to be missing a lead on the card inserted in the left - typically it has one white and one black (You can see the golden connector where it presses on next to the white)
My guess is the lead that's disconnected is flailing around causing parts of the mobo to bridge and short.
You have two sticks of RAM there on the right of the photo, held in with two metal arms - if you press them away from the module at the same time it will pop out.
Can see quite a bit of dust there, can be the cause of a lot of shorts.
If you need to replace you are looking for PC2 5300 at 555 speeds
Do what I suggested first. Had similar issues with countless PC/laptops and it's nearly always static causing it.
I tried that the other day and it didn't work :( But I'll try it again just to make sure!
Yep you got two sticks of RAM there on the right of the photo, held in with two metal arms - if you press them away from the module at the same time it will pop out.
Also looking at that photo, it seems to be missing a lead on the card inserted in the left - typically it has one white and one black (You can see the golden connector where it presses on next to the white)
Thank you very much! I'll try it out in the morning :)
Right, just took one stick of RAM out and this time it managed to get past the Samsung screen but just went to a black screen with a flashing cursor in the corner. Couldn't press F2 or anything. Second one same thing happened but it just went to a black screen.
I see what you mean about the lead, I assume if another lead had somehow disconnected I'd be able to see it though?
They are normally tucked away - might be able to find it if you dig about...
your wireless isn't caput by any chance ? (Assuming you don't use a plug in dongle)
Looks like it's the main that's connected, this could perhaps run on a single antenna cable (it would be the 1st Iv'e seen) They normally stem down from the monitor.
When you mention the flashing cursor, I suspect it's the waiting to type style icon. Sounds like it's failing to POST. Next step would be to get some RAM from something reliable to rule that out.
Yeah thats the icon thats flashing. Do you think I've tried most things I could do myself? Next stops gunna have to be a computer repair place lol
If you where nearer i'd check it for you :(
Look's like it will need to be passed on to somebody but im sure that network cards meant to have 2 plugs ;)
Odd's are it's just fubar RAM though - if you had another laptop handy they all tend to use 200 pin 555/667 RAM so you could swap them over.
Ahh right, I have actually got another laptop that has a broken screen so I could check and see if they're the same. Is it the bit on the left with the wire that I'd want to swap over or the 2 RAM things?
Just swap one of the modules from the other laptop so you just have one in your laptop.
I doubt it is anything to do with the cable being missing as my old laptop only had one wire once i was finished with it! unless of course it is shorting something out inside.
I RAM doesn't work you could completely remove the network card and try that but if that doesn't work i would put money on the motherboard being knackered.
Try removing one module of ram then try the other as I said. 1 cable for the wireless card isn't unusual! Usually have two or three though :)
Google how to change ram on your laptop and you'll see :) just take one stick of ram out first if it acts the same then take out the other and put the first back in :)
See how you get on. Private message me for more help ... After all I run a laptop and computer repair shop :)
the card has no missing cables, the second connector you are looking at is just an aux... 100% not related to her problem and is correct the way it is.
I thought it was worth suggesting, I've not seen one with a single connector and I've worked on a load of netbooks/laptops/desktops for HP.
With the nature of the issue it was a longshot as it would be more intermittent.
Have you had any luck with the RAM Emily ?
Hmmm I see what yu did here.
Quick shutdowns not fully rebootin' like you should. You're lucky that hundred shot of volts didn't blow the solders on the motherboard! You almost had me? Now, me and PC world got to rip apart the processor... and replace the solenoids you fried.
:lolup:
Yeh was going to mention that second connector wouldn't be the problem. Maybe taking out the CMOS battery for an hour to reset the BIOS. It may help it may not is it beeping at all the laptop when it starts?
Nick
Haven't tried switching it over with the RAM from another laptop yet but I'm going to try it later :)
Nick
It's beeped a couple of times when I've turned it on but then other times it hasn't?
is it showing anything on the screen now after the beeps ?
In reference to the beep's - what was the pattern (e.g high, low, high, low)
Thinking about it, I think it just beeped when I went into the bios before it froze. It would just do one short beep.
Just tried swapping over the RAM from another laptop and it just froze on the Samsung screen :(
Think I'm just going to have to pop it into a laptop repair shop and see what they say.
Also Try removing the battery and power cord from the laptop and then hold down the power button for 10 seconds. It may also be worth removing the CD/DVD Drive and Hard Drive if able to put the battery back in and power cord then power up the system without these in and see if anything is different?
Nick
