Aftermarket wheel but retain C/C - is it possible?
Has anyone managed to do this? I want a aftermarket wheel but really want to retain the cruise control somehow.
I think someone used a ph1 headlight stalk with horn button on, wired the horn up to the +, the clutch is essentially the same as 0 so that is all you need.
Steve (Steviant) has this in his 182. Just retro-fitted simple buttons on the wheel with the appropriate wires hooked up.
Wasn't there a bit more to it than that?
I remember him saying something about a board because of the way the standard rocker switch worked...
http://www.cliosport.net/forum/showthread.php?500121-Sabelt-Steering-wheel-Cruise-Control&p=6612842&viewfull=1#post6612842
[URL]http://www.cliosport.net/forum/showthread.php?500121-Sabelt-Steering-wheel-Cruise-Control&p=6656537&viewfull=1#post6656537
[/URL]
Im doing this at the mo. Using a sparco mount with 2 buttons on already, will add the other 2 myself (from tweaks) The problem is they aren't normal switches, they use a resistor to show a resistance to the ECU. You need 910, 275 and 100 ohm resistors, the other is a straight switch so no resistance.
I'll do a guide as I go through it, waiting for the mount to be delivered at the mo.
ETA: or you can use the OEM board but I wanted it cleaner.
Ian I'd be interested in your guide! . I ordered the sparco buttons from Tweeks. Sent them back though coz I just cba with it all lol.
Sounds more complicated than I thought though!
