Anybody know the vvt trigger oring part number
  iceberg 172
iv got the ones for the coil pack and cam caps now just need this one. myt have a go at spraying the rocker cover to while im at it all
  182
The seal you need comes in this kit and may have gone up in price now
Camshaft oil seal kit - 7701471629 - £25.62
  iceberg 172
haha well if you could post it for me tomorrow fred ill try and check in work as im goin to renault on the way home. thatll be great. does anybody know how mutch renault are going to rape me for a coil pack and are they on exchange or not
  Lionel Richie
the VVT seal is about £4 (i doubt they'll have it in stock)
coilpack from GSF or ECP etc? much cheaper
  iceberg 172
ive just been on ecp they dont have the valeo one in stock will the other be ok i think its arc or somthing like that
  DON'T SEND ME PM'S!!
I've sealed up a couple of solenoids round the plug too. If the plug moves in the body is has leak potential. Unusual, but there's no harm in it as you have it apart.
no, if you pull the solenoid out, you will notice where the plug sticks out the body of the solenoid there is some movement. I've seen oil weep out of there
  iceberg 172
ah right fair nuff. will on topic of vvt how does fitting vernier pulleys work. i understand that this removes vvt but i dont understand how you would benifit from this. i know you need none vvt cams do you need a aftermarket ecu aswell
you honestly won't need verniers unless you plan to go very very far with tuning, infact retrofitting vvt from a 197 would give you more benefit as you could control the timing completely rather than have it fixed. This would need an aftermarket ECU though, and a cam angle sensor adding.
I've fitted verniers before, and we decided it was pointless as we could just fit standard non VVT pullies (exhaust cam ones) and have adjustment that way
  iceberg 172
i was just wondering as my dephaser pulley has started gettin tappy and was loocking at diffrent routes to go down
you would need to replace the inlet cam too. Honestly the standard dephaser is pretty decent as long as you change the oil regularly for good quality stuff
