partial misfire, high fuel usage, O2 sensor voltages ok, probably injector?
Car  172 ph1
Currently having a misfire where the power loss is perhaps 30-40% - I can still get up to 150-160km/h on the highway but not much higher, there is the characteristic "motorbike" sound, and the fuel consumption is huge.
Spark plugs, leads and coilpack are just over a year old.
Hooked up an OBD reader from which I can see the pre cat O2 sensor voltages see to be ok - fluctuates between 0.1 and 0.8V.
MAP sensor showed 40kPa. Coolant temp showed 88 degree C.
Long term fuel trim was 37.5%
Calculated engine load was stuck at 100%
I'm guessing it's the injectors?
Took the fuel rail out yesterday. Cranked the car over with wife's help and saw that one injector was not working.
New injector ordered. Hopefully problem solved.
hi there, how much did you paid for the injector?
It was around 80 Euros from the Renault dealer, I was in a hurry. They're probably much cheaper if you buy reconditioned off ebay.
Changing the injector solved my problem.
