wheel size pros and cons??
  renault clio
Was just wondering what the pros and cons of having 15's on are as opposed to 16 or 17's? heard about better acceleration on smaller alloys etc but are there any other impacts?
Chris205
  Many Things
Would need less modification's needed to the bodywork/arches if you fit smaller wheels yeah. Fitting things like 17's then coilovers and putting it down very low will require modifications to the front arches, never had a clio on 17's for the rear end so you'd need to check that out.
  mk2ph1 rsi 106rallye
if smaller wheels are better why do rally cars touring cars ect all use 17"+ alloys???
can fit 17s on a clio and lower it without having to modify anything without any problems if you run the correct offset wheels.
15 and 17 tyres prices are nearly the same in common sizes.
  Lotus Elise
BTCC cars run 17 inch due to regulations.
  phase 1 flamer 172
I do not see why 15 inch rims give better acceleration, as the wheel dia gets bigger , the tyres normally have a lower aspect ratio, so overall dia is very similiar .
  RB 182 Cup
Generally smaller wheels weigh less, therefore less rotational mass and less torque required to accelerate them to any given speed. The mass is also closer to the central axis (hub). Cast your mind back to playing on roundabouts, when you lent out it slowed, when you moved into the centre its rotation accelerated and all with no external forces (mum / dad pushing) acting upon you.
i.e 17" have most of their mass further out than 15" wheels. 2" give or take depending on the rim construction.
Or something similar if I remember my A level Physics and Rotational Dynamics right :-|
  phase 1 flamer 172
I would imagine that trying to pull a ton of car along takes more effort from the engine than trying to rotate a pair of wheels
  RB 182 Cup
Isn't every kilo lighter a wheel is equivalent to something like 4kgs when it's rotating?
Something like that anyway.
It is, 1kg lost of unsprung weight is approximately equal to 4kg lost of sprung weight. Sprung weight being anything held up by the suspension, unsprung the remaining, some suspension components, brakes, wheels and tyres.
Reducing unsprung weight greatly increases driving dynamics, increasing it makes the car feel heavy and unresponsive.
  RB 182 Cup
Tyres can vary in weight considerably too.
I remember ready an article on an MX5 website I think which weighed a number of 15" tyres. They varied by over 2kg I seem to recall from the heaviest to the lightest.
  phase 1 flamer 172
Absolutely, but the engine will have to work harder to accelerate the car if you increase the rotational mass of the wheels and the brakes will have to work harder to stop the car if the rotational mass is increased.
http://www.ux1.eiu.edu/~cfadd/1150/09Rot/RotDyn.html
Yeah and going from a 5 inch dia rim to a 30 inch for example would make a difference, but going from a 15 inch to a 16 or 17 is not going to be noticed, and as you say in your other post , what about the tyres,i would guess a 195/50 x 15 could weigh more than a 195/45 x 16 because of the bigger sidewall, and this is weight at the on the edge where its more noticeable. So no i dont see a 15 inch rim helping a car to accelerate quicker than a 16 or 17 inch rim.
  phase 1 flamer 172
No you wouldnt, because as wheels get bigger, tyre aspect ratios get lower, a 195/50x 15 is as near dammit the same as a 195/45x16, thats my point the overall dia dosnt change, obviously 20 inch rims may be taller and do as you say but thats not in this discussion.
I agree 100% with 105e...try to weight a 195/50R15 or a 195/45R16...considering same tyre maker, the 45/16 is more or less 0.8 lighter than the 50/15....so what you save for the rims you will lost for the tyre weight.
I agree that the handling is completely different, 16" are funnier then 17"....but don't think to accelerate more or brake better...the overal diameter is exactly the same....
