r****d
Donny_Dog
Car  Jim's rejects
Yes, I have been called this in the past, but thats not the sole reason for this question.
When boosting an engine (thats not originally a turbo engine from the factory) I have seen that: retarding the ignition timing will keep the engine safe.
What does this mean? Why must the ignition be retarded - to keep it safe from what?
Is this the same when not running boost - but yet increasing horsepower from say... throttle bodies?
I don't understand.:S
It stops DET which is a factor of heat and cylinder pressures being too high.
Your moving the spark towards TDC, in some cases after it!
Essentially, you 'r****d' I.e. back off the ignition timing to fire slightly later. It helps combat pre ignition - I.e. detonation.
You can't just do it though, with old distributor days yes, not now - the car needs mapping to back the ingnition off.
What about using adjustable pulleys?
You could use cams, adjustable pulleys, turbo's, superchargers - whatever you want mate - the power all comes from the mapping. Gone are the 'rs turbo' days when you guessed the fueling and ignition....
Get it turbo's if you must - let the mapper sort the ignition.
