Im not convinced you will find a megane any more reliable at the same power than the astra TBH if both are driven the same way etc.
It's the same basic engine as the Clio and they can bend con rods with over 300lb of torque.
If you got 22mpg I expect your injectors where shot.. Mine does 29-30 day to day and that's on stage 2. 276bhp 330lb torque. That is your very limit torque wise with the standard engine internals/clutch mind.
Nope it had new coils, plugs and injectors with a map they are ment to be far better on fuel though...
They are the same rods mate.. I can get it to do 35mpg on a long run on the standard map.
Meganne 225 left, RS1*2 on the right.
I've seen this photo before I think. And it came up on meganesport. The con rods are the same part number off Renault though.. So that is a bit strange..
Tunst something wrong with your megane then.
mine does at least 28mpg with ease. rods do go over numbers and are like chocolate when your at 300ftlb of torque
I've also noticed no one seems to bother with s/s exhausts? Is this purely because they aren't that old yet or are standard exhausts pretty unrestrictive as is?
