Gearbox problem
  Clio 200
I have a clio 200 which I have had for about a month and everything was fine up until now. I started the car this morning and couldn't get into gear. I have tried pressing the clutch continuosly and still won't go into gear.
The car only has 11,000 miles and there have been no previous problems.
What can I do?!
R-Sport.
  Mint 1*2's for sale-
Hum- a chance an issue with the clutch but more than likely a new gearbox...-
Get it into Renault to check-
S
  Megane r26
What can I do?!
Seems strange how it was fine one minute then knackered the next, usually get some sort of sign.
Can you get it into gear with the engine off?
  Clio 200
I did some motorway driving yesterday and this is the first time I have gone to use the car since. Goes into gear with the engine off but sounds a bit clunky
  Megane r26
I'd be looking more towards the clutch tbh (pretty sure there hydraulic) so possible slave cyclinder/master cyclinder failure. I've had it on a megane very similar issue an it was caused by a little diaphram on the clutch pipe leaking giving me no clutch effectively, when you try an put it into gear with engine on does it crunch?
  Clio 200
My warranty ran out 3 months ago! I managed to get into gear and have a little drive but it doesn't feel right from a cold start getting into gear.
  Megane r26
Sounds like a clutch problem but don't hold me too it, take it back to them they may nonour it or give you some sort of contribution if you are lucky.
