Gearbox problem
Car  Clio 200
I have a clio 200 which I have had for about a month and everything was fine up until now. I started the car this morning and couldn't get into gear. I have tried pressing the clutch continuosly and still won't go into gear.
The car only has 11,000 miles and there have been no previous problems.
What can I do?!
Hum- a chance an issue with the clutch but more than likely a new gearbox...-
Get it into Renault to check-
S
What can I do?!
Seems strange how it was fine one minute then knackered the next, usually get some sort of sign.
Can you get it into gear with the engine off?
I did some motorway driving yesterday and this is the first time I have gone to use the car since. Goes into gear with the engine off but sounds a bit clunky
I'd be looking more towards the clutch tbh (pretty sure there hydraulic) so possible slave cyclinder/master cyclinder failure. I've had it on a megane very similar issue an it was caused by a little diaphram on the clutch pipe leaking giving me no clutch effectively, when you try an put it into gear with engine on does it crunch?
My warranty ran out 3 months ago! I managed to get into gear and have a little drive but it doesn't feel right from a cold start getting into gear.
Sounds like a clutch problem but don't hold me too it, take it back to them they may nonour it or give you some sort of contribution if you are lucky.
