Spacers 182
Car  BG Clio 182/RR Sport
Hi Guys,
Thinking of fitting some wheel spaces on my 182, whats size should i get? Do they just fit behind the wheel or do you have to remove disc etc?
Also will i require new wheel bolts?
Help welcome!
Depends on what you go for. The spacers fit between the disc and the wheel. 'Hubcentric' spacers have a lip for the wheel to sit on just like the hub on the car and they are machined specific for different makes of car. For example:- Clio 182 is 60.1mm bore. You can get universal spacers cheaper as they are not hubcentric but obviously these don't fit as good. Hope this helps
I would only recommend hubcentric bolt to hub type spacers, and if your thinking of going on track don't settle for the cheap eBay s**t.
