Ahh yes the on Citroen Relay van had its rear tyres changed for the first time at over 70k
I did think this was a Clio forum for a minute!Well you never mentioned that in the OP :rasp:
Brilliant. No complaints - just as it should be. Not too bad in the wet either.how do you find the pirellis bud?
Just picked up a pair of Michelin Pilot Sport 3's brand new for £150 off here.![]()
I've no idea, they're in my back room...i've read that the soft sidewalls ruin the cornering/ride....or is that just rubbish?
Best tyres i have ever had on my clio, it felt so safe with them on. And they were second hand due to being on the turinis i bought, they had around 4mm.
4mm tread michelin> brand new t1r's
Would the Rainsports be any good on track? Like just occasional use...
I think I'll swap my front's with the rears when I've done about 7000 miles on them. I like to replace all four at once so that should give reasonably balanced wear.
My dad managed to get 50,000 out of a set of bridestones on the rear of his fiesta. He drives very sedately though.
Bad Idea. You need to have Just as Much Grip from rear tyres if Not more mate. Last Thing You want is the rear end to lose grip suddenly On surface water.I think I'll swap my front's with the rears when I've done about 7000 miles on them. I like to replace all four at once so that should give reasonably balanced wear.
