Clio 172 Phase 2
Hey everyone
Recently started a new job, so not been able to spend quite as much time on the old interwebs and what not.
However with doing a few more miles now, I've recently had quite an annoying noise get slightly worse on my 172. I’m sure it's coming from the OSF area, but can't seem to narrow it down quite enough. The best way I can describe the noise, is if you had a spoon in an empty cup, and stir it around lol, I know that doesn't make much sense, but that is close to the noise it's making. I’ve recently replaced the OS drive shaft, but couldn't think of anything that would cause that sort of noise that I would of disturbed.
The noise can be a bit random in occurrence, as some bumps will make it do it, some won't.
I’ve heard similar noises on other cars, and it's turned out to be brake pad chatter, however I'd like to think I could rule that out, as the pads fit very nicely in the shims, and have plenty of copper slip on them.
Any thoughts would be very much appreciated, as the noise it driving me nuts.
Thanks
Gaz
Thanks
Gaz
