I cant fix misfire cylinder 1 error , help is needed asap
Car  Arctic Blue 182
I bought a Clio 182 cheap knowing it had a p0301 misfire cylinder 1 error ,I bought it attempting to fix it but its starting to really frustrate me now!
The engine management light only comes on at idle but goes once your driving it ? The light flashes and only comes on like 20 secs after its started?
It hasn't got a misfire as such its more of a rough/lumpy idle?
I have done the following in order to try and fix it :
Changed the coil pack = no difference
Swapped the spark plugs around and scan it to see if the fault code moved to a different cylinder = no difference
Swapped injector= no difference
swapped leads = no difference
However i noticed a tiny bit of oil on the end of the lead where the lead connects to the plug on cylinder 1 today?
i have done a compression test and the figures are the following:
cylinder 1 is nearest the gearbox,correct?
4-3-2-1
190-190-190-177
I'am starting to think its a valve on cylinder 1 ? Do the valves tend to burn out or get pitted on the F4R?
Thanks Daniel.
Couple of things to do. Compression test on cylinder 1, & check ECU is triggering injector one, either with a noid light.... or if ya brave..... see if the actual injector is spraying.
4-3-2-1
190-190-190-177
Thanks Daniel.
Take the plug out of number one and drop a little oil down the bore, re do the compression test and if it goes straight up to 190/200 then you know its the rings and nothing to do with the valves, i would not worry to much as 177 is still well in the green mate
Try removing injector rail and swapping two injectors around refit and see if code changes.
While the rails off you can check the spray pattern from the injectors.
