Car won't start help
  Clio 197
Hi I'm a newbie and have not long owned my clio sport 197 when I got in it this morning put my foot on the brake and pressed the start button the lights on the dash came on but didn't try to start, there are lights on dash as normal but will not even attempt to start PLEASE HELP !!!!!!!:S
  Megane r26
I've heard starter failures aren't unheard of, do you get any sort of clicking from the starter?
Have you tried bumping it? I only had my 197 for 10 months so never really encounter an issues.
Jack!
Sounds like the starter motor, possible problem with the solenoid. Try giving it a tap with a spanner or something, lightly mind, and try disconnecting the wire connected to the starter motor and check the connection is clean.
  Megane r26
Doubt it will be corroded at that age, if you are going to tap it with something don't use a spanner.
If you short the terminals you will know about it! Use a hammer handle but I'd be suprised if you can get at it easily.
