Headwork, cams and remaps
Grandpa Joe
Until I go turbo I'm looking at getting a spare head ported and polished and get some spare cams reprofiled by Piper cams or get the Prima racing cams.
However I'm unsure of what remaps are available to go with the head and cams. Can you live map the Ecu?
batesey
  172 Cup Turbo
If your going down the turbo route, I would leave standard cams in, put the money towards building a good boosted setup, low comp engine etc
  182, SQ7, Trafic
I've got an engine that needs a rebuild if that interests you. It just needs some piston rings really so would be perfect for a decent low compression rebuild,
Only want £200 for it.
  172
i've also got a ph1 lump on 85k with belt done on 70k, if you want a engine you can build over time and drop straight in, £300 + delivery, will come with service book and any receipt's relating to it
Adamm.
Good engine this, was my old ph1 and it definitely felt faster than what the current 182 does. Pulled well.
  172
if it doesn't shift soon i'm half tempted to keep it for a HI-comp rebuild even tho i keep saying i want out of clio's lol
  182, SQ7, Trafic
You'd be better selling that as an engine to drop straight in rather than to rebuild!
