Painting grill
Car  clio 1.2
Hi I want to paint my grill and was wondering what paint people used or if any one could recommend a good brand of spray paint. Don't want to use cheap spray paint that won't last. Thanks
find a local paint/bodyshop suppliers and get paint from there, alot better quality from the likes of halfords
Halfords spray paint is fine, its very thin so it needs a good few coats. Also best done in direct sunlight or very hot weather so it dries instantly.
I'm not exactly far from the business either ;)
It's just a lot thinner so needs more thinner coats to layer it up. I've sprayed numerous amounts of wheels just in Halfords spray paint and people in the business wouldn't believe it was all rattle cans.
As long as your painting onto a decent heated surface in decent conditions the finish will be spot on.
Only picture I've got of the last set and they're very dusty. You can see how smooth the finish is.
Rattle cans on wheels and grilles are fine, especially on the grilles as its so fine its hard to rub down correctly. Meaning you need more thinner coats rather than fewer thicker coats.
