You can just remove the pump and associated pipes and run the rack dry, However. parking is a nightmare, lol
If you have a 182 then you need an aircon delete kit, The pump can be completely removed and run the long stretch of the belt over the top rather than the conventional bottom run, A 4 rib belt needs to be used as the 5 would foul the cambelt cover.
A late citreon Saxo electric pump can be used if you still wish to have power steering, As the pump is only a feed and return it is easy to plumb.
HTH
