Jet washing ?
Car  Clio 172 Phase 2
Alright dudes my engine bay is in clip from the oil leak I had. Is it ok to jet spray all round and inside the engine bay or will it pop the electrics ?
Okcool. Yea my wipers play up all the time put them on intermission and some time they go as they should then sometimes go full speed lol. They got a mind of there own lol
my non-sport did that for a while... remove the fuse from the passenger side panel of the dash and leave it out for a few hours, replace fuse and it will reset it back to working normally again
and best bet with the bay is to attack it with degreaser/WD-40 and alot of elbow grease as said above :)
Ok cool il give that fuse ago
top man, it will sort it :)
Sorry to jump in here but is a steam cleaner safe to use near french electrics?
steam is water no? ;)
haha, if you absolutely had to I would recommend waterproofing all the electrics with bags and tape etc first....
but bear in mind: steam will get in places that water wouldn't and will condense back into water once it cools so may cause problems
Lol yes I know but it's not going to soak everything like a pressure washer. I doubt it's something ill do just my mum got this little steam cleaner thing and I thought if I get the chance one day I may have a little crack.
As tony said though I generally just try not too look I certainly don't plan on showing it off anytime soon haha. I'd probably only use it on the inlet area to clean the grease and oil residue away any way.
:P
and I know the feeling, 'luckily' my engine broke and I took a day in between removal and fitting the new one to do mine by hand with WD-40, but mine won't be on show either, if it is only that area you are after doing then cover the rest with a plastic sheet, clean with steam cleaner, then go over it with WD-40 afterwards to clear out any water that might have got in :)
Yeah doubt I'll bother tbh lol not worth the risk. I have lost all interest in all this cleaning lark these days anyway, only cleaned the bloody thing once since I got it in January :o.
I'm going to clean it next few days though as this weather is bit better now.
that is bad! :nono:
haha sure you will get some love back for cleaning once you see how shiny it looks ;)
When the engine blew 2yrs ago, I still didn't like getting the steam cleaner in there, didn't seem right.
Full chemical and full temp, :eek:
