Hiding info of a jpeg
riz
  Jaguar XFR
I am emailing someone some photos, but i dont want the person receiving the email to be able to right click and find out where the jpeg was taken and what site. I have the permission of the right holder to use the jpegs.
Is there a way i can email the photo and either lock it or get rid of that info? I guess i could add the pics to a protected pdf maybe?
(its about 15-20 photos)
DrR
  VW Golf GTD
take a screen shot of the photo, then email that?
Heez
  Superleggera'd Bean
Open photoshop, open a new file, open photo, drag photo into new file, save as whatever you want.
riz
  Jaguar XFR
Cheers ill have a look at imgur, not keen on Fboom uploading.
SharkyUK
​looks good but how do i install use iT?
It's a command line utility... are you using Windows?
The easiest way is to create a directory, copy your jpg's into it and then copy the jhead.exe file in there as well. Then go to the Command Prompt and change to that directory. It's simply a case of doing something along the lines of:
Code:
More information here: http://www.sentex.net/~mwandel/jhead/usage.html
If you're still looking for this, Right click the image where-ever its located and Goto properties, then select Details. should be a link underneath the details saying "Remove Properties and Personal Information" click it and remove the info you wish.
^ Windows 7 instructions should be similar for xp/vista etc... though.
Hold ctrl when selecting images to select more than 1 file and you can do it all at the same time too as you can remove multiple values this way as well.
  Too many
He's on OSX mate.
