Cooksport Springs+ Camber Bolts
I've had my Cooksport springs on for a couple of months now and since then I've noticed a small amount of uneven wear on the front tyres. The inside is wearing a little faster than the outside.
Couple of questions...
Is it necessary to correct the camber with Eibach camber bolts for the 25mm drop?
Will getting the tracking aligned rectify a little of the uneven wear even though the camber remains unchanged?
Thanks :approve:
If you didnt do alignment after fitting the springs then thats where the un even wear is coming from . Toe is more than likley incorrect . Tracking should do the trick
What camber are you running, and what toe are you running.
No idea on both. I'm going to get the tracking done tomorrow, and we'll see. I can actually see the toe in on the front wheels though, I imagine there will be some comedy numbers on this thread tomorrow.
As for camber, the only difference is the 25mm (ish) drop from the cooksports. I can tell it's got more negative camber compared to standard springs, but that's it.
My gf had the same problem on her car a while back! We were sure it was the camber killing them as hers was running loads of negative and car seemed to drive ok so we presumed the toe was okay! Took it to a well known tracking company near us that set up a lot of motorsport cars including my own and turns out that it was the toe killing them cause thats all we adjusted and they are perfect now :)
Well the toe was way out as expected, but that's all done.
What's more concerning to me is the camber:
LEFT 1.46
RIGHT 2.21
That's bad right?
Calculated the true effect of this.
The left wheel is 1 degree, and the right wheel is 1.77 degrees away from nominal. So the top outside edge of the left tyre is 5mm further inside than it should be. The top outside edge of the right tyre is 8.8mm further inside than it should be.
Significant? Should I get the camber bolts?
Can no one help? Are the following camber measurements a problem for handling and/or tyre wear?
LEFT -1.46
RIGHT -2.21
Edit: Clearly they are out of spec and I have bought camber bolts. But I just want to know if this is a "holy s**t get that done now!" or a "it can wait a couple of weeks/months".
I would probably suggest getting some camber bolts and getting it set up between 1-1.5 degrees negative camber if you want it set up for handling, only going on what I run on my Nissan pulsar track car mot sure if the same applies to clio's exactly but I would say you at least want them to be even!
​Sure someone can clear it up for sure tho!
I noticed a similar issue, although my CookSports have been fitted for well over 6 months now. I had alignment done pretty much straight afterwards and it was a lot better but still not perfect. I have Eibach camber bolts fitted now and it's near perfect!
LEFT -1.46
RIGHT -2.21
​It's not the end of the world, but could do with being done.
