horns not working
Car  Renault Clio MK4 RS
Hi all,
Like it says on the title.. horns randombly stopped working. Checked fuses and its not that. Also cant get the horn bit off the steering wheel for some reason. Plus the guide on my phone is unclear so i dont know what im doing..even though the airbag and cover seems to be stuck on.
Any help would be great!
Thanks
Remove passenger side front wheel arch liner and disconnect the horn connections clean them up and wd-40 them.
Give the horn itself a whack while someone presses the button.
Also clean up the bracket where the horn attaches to it, it's a single pole horn IIRC.
Hell if its a 1.2 8v you should be able to reach down with your hand and get to the connectors, give them a push on and try again.
