Part number
  A special one.
I take it you mean a cam cover gasket?
There isnt one, its sealed with sealant.
Your car is a 172 cup, no need for the other stuff.
  A special one.
You do know that you can not remove the cover with out removing the cam belt?
The cam cover also holds the cams in place so to fix the leak would also mean a full cambelt and aux belt kit.
  A special one.
Flol, if the leak is coming from the fixing bolts then these could be removed one at a time and be sealed.
