one side light is wrorking but the other one is not /my dashboard lights so i couldn'
Car  Clio 1.2
hi there i put new side lights in my clio 1.2 16v 2002 one side light is wrorking but the other one is not i swap them around and still one side is not working but b4 i took the old ones out they wer both working and my dashboard lights so i couldn't see what speed i was doing! but the lights was on
Re: one side light is wrorking but the other one is not /my dashboard lights so i cou
Sounds like it could be a fuse mate.
Open the passenger door and pop of the fuse cover behind the glove box so you can check.
if i do that will fix the side light and light up the speedo ????
may be conection on the bulbs to holder
Check fuses
how would u fix this
how would i fix that
Open the little compartment on the side of the glovebox and look to see if any of the fuses are broken. There's a guide on the back of the little panel you remove, use that for reference. Take extra attention to the ones with the symbol of a lightbulb on them.
patience and brilliance :)
