If you have the map light, it's two W5W (501) bulbs.
If you don't have the map light, you need to be handy with a soldering iron to solder in two bulbs, one opposite polarity to the other. 38mm Festoon. Or you can just get the maplight!
I've got a crappy flippy one in the trophy, easy swap for a spot light style one? Something I miss about my FF!!
The crappy flippy ones give off waaay better light though!
That's because you've got s**t bulbs lol.
I thought the bulbs you suggested for the maplight were the ones you use, which IMO are a bit dim.
In terms of lighting the standard interior light I just had 16SMD festoons, jacked together like so: (one is reversed)
But I suspect you can get away with 2 24 or 36 SMD panels next to each other (easier to solder actually), I've got 2x 48smd panels here but they're just too wide to get 2 into the holder.
http://www.ebay.co.uk/itm/Car-Inter...arts_Vehicles_CarParts_SM&hash=item4aaebf1626
... But it's still far easier to just do the maplight conversion lol.
Is the map light really that better? I have the flip-style and it seems pretty good, i was just going to get a very bright light for it!
I might go for a scavange round some dead clios to get a map light, Dash dimmer, spare vents and other goodies!
am i best sticking with a non-led festoon then?
So, I have had a look and have found these sidebulbs which appear to have a different fitting to the astra ones... are these the same or are they actually different?
http://www.ebay.co.uk/itm/Renault-C...Model:Clio|Plat_Gen:MK+II&hash=item51a7142afe
http://www.ebay.co.uk/itm/1x-Blue-I...Model:Clio|Plat_Gen:MK+II&hash=item3f1d984a24 so this one has exactly the same details as the original so will this work as a festoon light?
In regard to the courtesy light? No.
Will work in the boot though!
It'll work in the flippy one. Well, as well as any LED works in it.
