Wilwood caliper brackets
Car  Clio 182
Does anyone know where I can purchase the caliper brackets for the wilwood 4 pots?
i can only find the whole kit for sale.
Not very hard to just make your own for whatever size disks you want to run, thats what I did for my 6 pots
Probably best going to Jampsport or K-Tec and asking.
I'd be interested in some too actually. Preferably the Jamsport ones to allow for the larger disc size.
I cant picture what a universal lug mount could look like TBH!
Other than just a lump of metal you drill and cut to fit, FLOL.
Feck paying £250 for brackets. The whole setup is only £600
Just phone Jamsport and K-Tec - see if they'll sell seperately as they both sell willwood kits for the Clio
Well it's €250....euro...
so it'll be cheaper in sterling ;)
(£200?)
The bracket to fit 406 brembos to mk2 clio's is €95 from the same company who make the meggy brackets.
But then you can get a pair of callipers for less than £200 and hoses for £50 (front and back) which gives you a much more superior setup as the swept area and pad area are massive in comparison to K-tec, jam sport and who ever else uses that callipers with a different badge on them.
You could almost if not buy brand new meg brembos, disks, pads and hoses for the circa £650 these company's want for their basic 280mm kit.
The quality difference between the meg calipers and willwood ones is very marked, Ive used wilwoods before and no doubt will again if I come across a set at the right price, but they are very cheap and cheerful.
I removed mine off the Clio yesterday and was really impressed as I was expecting to see the seals brittle and damaged but they were fine, I must have clocked up about 1000 track miles and 1000 road miles in between without even going near them. I was melting centre caps, spigot rings, and powder coat so had some heat through them.
You interested in a pair of cast superlites chip? I've got a pair of lug mount 4 pots that will be for sale soon. 310x32mm rotors on ally bells as well.
But the meg setup requires 16" wheels too?
