Remap BHP increases
ok, my water temp is always ok tho. dont no what to do
What is your water temp then? Have you actually measured it with an RS Tuner for example?
If you are going to say "middle of the gauge" then please note that covers a huge spread in temperatures and is therefore utterly meaningless in this context.
Like mine, when the engine is off it shows at the 2nd bar as I fucked the dash light up and can't be arsed to set it back, so a good temp for me is about 3/4s of the way up.
OP if you have an RStuner just do the live data program, it's pretty damn useful.
Then I don't no mate
I thought the rev limits were different in the gears but still got it wrong, sorry.
This is interesting;
The FIA rule demand to keep the sensors of series present on the engine.It is possible to modify the connctions of cablage as well as to change the ECU Box.Concerning the characteristics of the modifications in to the Renault Sport ECU Box
The series engine speed is supposed to be 7250 rpm for 1 to 3 and 7000 rpm after. The Groupe N box is always to 7400 rpm limited 1 to 5.
Power + 8 Hp. (with the exaust system)
Torque + 1,7 Mkg.
Let me know if you need anymore information.
Lionel Hansen
Renault Sport Technologies
Direction Competition
* Standard map: 6800 RPM when cold. When warm it's 7250 RPM in 1st, 2nd and 3rd. 7000 RPM in 4th and 5th.
* Renault Group N map (standard on Renault Group N ECUs): 7400 RPM in all gears.
* Most/all RS Tuner maps & lots of specialist maps: 7800 RPM
I no mate. I need to grow a set. Just don't want no more problems with the thing lol. Cost me a fortune since I brought it lol
So guys what sensors affect the change of maps because I'm going to buy them
Reason being I've never tried to hit 7k or above because it runs out of puff at 6k something even after driving it for hours but i knew that wasn't right but it doesn't/didn't bother me till now
if its not revving up due to the cold map then id change the coolant temp sensor and thermostat. Start with the thermostat as its cheaper..
If its running out of puff at 6k. You have more of a problem than a CTS.
Just to stop the confusion
Maybe picked the wrong words but it will rev right up by 6k but then hits the limiter
Definitely not getting the 7250 or whatever its ment to hit other than that it drives fine I'll need to see again lol
