Rather then clog up the other thread thought id start a new build new and do everything in here and post up my progress (and failures probably!!
Specs of the unit are
Case = Xigmatek Elysium
Motherboard = MSI Z77A-GD65
CPU = i5 3570K (will be overclocked to around 4.4 - 4.5 Ghz) with Raystorm CPU cooling block
GPU = XFX HD 7990 6gb Gddr5 with EK waterblock 7990 Waterblock
PSU = XFX Black edition 750W
RAM = 16 GB Corsair Vengence Pro
Storage = Samsung 840 120Gb SSD for OS, Western digital 2TB "Green" HDD for games etc
Bitspower Reservoir
XSPC D5 Pump with multiport pump top
360mm XSPC Radiator mounted in top of case
240mm XSPC Radiator mounted in front of case
Fans = 6 Sorsair SP120 1450RPM fans on radiators and exhaust, Coolermaster Sickleflow 120mm for any other "intake" fans.
Fan Controller = Zalman ZM-MFC3 controller although may use my NZXT 5 fan sentry.
Various EK Compression fittings and angled fittings
MasterKleer UV hosing
XSPC Temperature monitor with screen
Mayhems Blue Coolant
Also some Sleeving from MDPC to tidy up and sleeve the wires inside. Yes I KNOW it doesn't make it perform faster...I just want to make it look pretty
. All PSU cables will be individually sleeved as well as all internal wires within the case and SATA cables.
The case is a bit on the small side though...
Radiators, Mobo etc
Pump Waterblock and fittings
Bitspower Reservoir
Radiators, Mobo etc
