Lag = time period between opening the throttle and the torque reaching 100lbft per litre
LMFAO well thats infinite for me - cos I never make 200lbft anywhere ever
Indeed, so reducing time down from infinite to under a second, is a big reduction in lag
ITBs are just lag-lag-lag-lag-rev limiter, change gear start again lag-lag-lag-lag-rev limiter etc
While the turbo cars are in the pits in a pool of melted pistons, turbo failures and drivability faults iirc.
We'll stop this here, been through it before.
Charged Clio's drop like flies on here due to constant problems, whether that's bad workmanship or the unreliability of cheap bolt on kits (which are more than cams, throttle bodies money with some change) I don't know, I'll draw my own conclusion from that.
LOL yeah and charged clio's don't pull away from itb clios as much as chip would like you to think
Cool, we can do two videos, one of yours versus a standard car, and one of yours versus a turbo car, and see if you are even halfway between the twoI'll fit my gopro for the next east mids meet
I'm not referencing your car in here as I know your just being greedy which is causing issues.
Go into every supercharged or turbocharged project thread on here and they have had problems x,y,z and they have done this, that and the next thing and now they want to split, maybe they get a 2nd wind and have another crack at an improvement but most end up in bits due to problems and cold starting, part throttle, WOT issues, turbos, heads, pistons, gearboxes.
I'm managing to run the C603D pipercross filter withe a smaller rad, on my DTH bodies without any issues
I left your car easier than your car would leave a standard one IMHO. I could hear when you were full throttle and when I was too the difference was huge, but I wasnt at full throttle for anywhere near as long as you (as I just didnt need to go and do 175mph to prove a point) so you might have a skewed view of how close it was or not I guess as you wouldnt know that.
So its made more than the twice the difference your ITBs have.
Wether you view that as a significant difference or not is up to you.
Jump to 2:45 in this video:
http://www.youtube.com/watch?v=gy6hPSVKCVE
The silver Ph1 is cams and bodies, Id say I certainly reeled him in and spat him out quicker than the difference between an ITB car and a standard car.
Indeed, but Phil said he was considering it so my replies were in the context of someone who might.But not everyone wants boost.
things can go wrong (and do go wrong) but not everyone is chasing figures. I think people have to be realistic. Either be prepared to spend a lot of money and do things right, or on the cheap and increase the likelihood of something going pop. I think the latter case is commonplace on here, hence why a lot of boosted projects don't last long (same applies to NA builds, too). Getting back on topic, I don't think many people (not all) would even notice the difference between running, say, 90mm and 120mm setups; possibly noticing more of a difference between running the car on a cold day as opposed to a hot day. Maybe.
Trumpet length = Clio NA Tuning Viagra - size matters! LOL!
After watching the video I really do think you've been in some s**t ITB'd cars - it took you a LOT longer to "reel him in" than it does me to catch 1*2's on track.
I'm starting to see why you love RS2's so much if that's your opinion of ITB's
I don't think there's much point continuing this conversation until next year. Bring the RS2'd car to cadwell, and then let me know how much quicker you think my car is over a standard one.
I think you're vastly underestimating how much a 25bhp increase and a 150kg decrease in weight effects acceleration without even considering the torque curve.
What a load of rubbish, as Chip has said to many people try and get boost on the cheap and that's what leads to problem's.
So.......back on topic. Should I buy 120mm trumpets for my cup?
If you have jenveys and 90mm now then yes IMHO.
Do ITBs make the car 150kg lighter then? Or are you lumping a huge weight saving in with a modest power gain and then attributing the entire difference in laptime on a very twisty circuit just to the bodies?
And what about the rest of the car?
I believe I have.
'twas you dear sir that switched from "an ITB'd car" to my car
I'd agree if you took a standard car and whacked ITB's on it - you wouldn't get as much a gain as if you boosted it. But you was referring to MY CAR and I'd say my car will leave a standard car a lot quicker than your car would leave mine
You have and yes 120mm's would give you a bit more mid range torque - but considering you would need it remapping after and they cost about £140 to buy. I'd wait until you can be bothered to fit 421's and then do the cams and 120mm's and remap all in one
Knowsit, brother! :cheers:haha true, that's why I have 120's and plan to go bigger. Massive **** you see!!
If its *THAT* close, it will then effect how they breathe by covering up a big chunk of the filter.
I refer you back to my "mickey mouse ktec kit" comment earlier, lol.
Just by the proper ones from Jenvey @Tomo 172 !
Then jump to 6:00
I'm sorry but you're UTTERLY mental. My car leaves standard 1*2's for dead.
It's virtually neck and neck with Batesy's low boost turbo car (except mine isn't leaking oil or breaking down). It's considerably faster than Mikes RS2'd car. I had to sit at half throttle down the A46 not to push him into the field lol.
I really do get the feeling you must have been in some s**t ITB cars to get such a skewed opinion of them.
how much weight does a turbo kit add?
