Good god *breathes*
you sure you cant fit 90's on the ktec kit without chopping the bonnet? I think you will find you can
and as i say im under the impression 120's will fit with cutting the bonnet.
Not on a ph1 no. On a ph2 maybe but they'd be pressed against the bonnet latch bit on a standard bonnet and airflow would be kinda s**t to them
and didnt you cut your bonnet for 120's on the sf kit or was it someone else? and do you reckon 160's would fit on your setup? as thats what would be needed to match a DTH kit on 120's, which as before im told fits with the inner skin of the bonnet cut.
I cut my bonnet just because I didn't see any point having that big bulge where the latch used to be and you get more space around the filter.
The filter on mine was pressing against the bonnet - so I know for a fact on a DTH kit it wouldn't fit as they angle up about 10 more degrees (see above pics)
And i was talking of putting the angled spacers in between the bodies and trumpets not angling the whole lot. that would create the ' ^ ' shape i mentioned before, and as mentioned before is the same approach pure motorsport have taken with their inlet setup.
Ok well I've never seen their inlet so no idea, but it's still money you don't need to spend if you buy the "proper" kit instead of the KTR branded stuff
Bearing in mind the ktec kit is in fact jenvey, an application specific kit being no more expensive than a more mass produced universal setup is actually quite good IMHO. there must be a lot of tooling costs involved.
How does that make any sense when the application specific kit is a poorer design/fit than the standard setup?
What youre basically doing is drawing up nothing more than assumptions based on what you believe to be the facts when in fact youre wrong. and bad mouthing a kit purely based on who drove its creation.
What the literal f**k are you on?
I've posted pics. The KTR DTH kit sits 20mm higher than the SF kit. Regardless of if you have a ph1 or ph2 you'll need to chop the bonnet. That makes it a more difficult fit than the SF setup. If you fit angled spacers that makes it more expensive too.
Do you work for K-Tec? Do they send you a gift voucher for christmas or something?
If it's such an epic setup then ask yourself why Jenvey still sell the SF kit direct and it's only K-Tec that sell the DTH setup. They just wanted something with their brand name on it.
