headlight correction with rotary polisher
So I've read through the Headlight correction without PC polisher and there is some good advice but I'm tempted to give it a go this weekend with my brother in-laws rotary and some 3M products.
Just looking to make sure this procedure/steps would be ok?
Wet and dry sand papers - 1200 - 1500 - 2000, possibly 3000? by hand? or should i use the sanding discs with the rotary?
3M Fast Cut Plus
3M Extra Fine
3M Ultrafina SE
Followed by a choice of sealant?
use the rotary for the sanding as well, quicker and easier. just be careful of the paintwork around the lights when you do the edges as the sanding discs will pull the rotary about a bit.
triple or quad tape the paintwork to be safe
I got at it with
1200
1500
2000
2500
compound then a finish so your steps would be fine imo
I definitely wouldn't use sanding discs on the rotary, you need to feel the light as you're rubbing down.
Thanks guys :)
Will use up plenty of his 3M tape that he moans about being so expensive ;)
Next question.... 3M products... Are they actually any good for this type of thing or should i just take my Scratch X along with me?
1500 grit is the lowest you should go down to. It takes an age to get them back from 1200 grit.
I'd also avoid using the rotary to sand them, you'll end up leaving deep marks that take forever to get out.
wet and dry at 1500 and take your time.
I had no issues at all using the 3m kit on the drill, perhaps that's less brutal than a true rotary then?
Lol. Get the 500 from a wood shop?! Far too coarse a grade for plastic headlights!!
indeed!! would never go 500! i thought 1200 would be pushing it so just went for 1500 then 2000 in the end, worked out a treat!
Before
After
I started with 500, then 1000 then 2000,30 mins each light
you can look at 500g being pointless in two ways.
one it adds more sanding to remove the marks incurred by the 500grit
two the plastic would have to be seriously pitted or damaged, not just UV damage and hazing before you would need anything even close to 500grit.
ie you made more work for yourself, and probably removed more of the headlight plastic than needed
Its what I do for a living, (vehicle restoration)
I DA'd them wet with 500. It removes the same amount as 1500 but 3 times quicker with a better result.
That's the best laugh I've had in years. Thank you.
Good God, I hope not. What's your company name?
How much would you charge to do my headlights?
I'd stay away. Give me a shout over the Xmas break and I'll come and see the Alpina and do the lights required at the same time. Swap a test drive for the lights.
Deal :)
