PMS cambelt protection plate
KitsonRis
That looks like a useful bit of kit. I refitted my arch liners recently as I was paranoid something was going to go into the belts, but on refitting it was still a bit unprotected. I’ll look at getting this!
mumpy
  Clio II RS 172
Any idea how this is supposed to be fitted? Does the crank pulley need to be removed for this to fit behind it?
G Hut
  ph1 172, V90 T8
Must use the same as this one, would have minimised my aux belt catastrophic fail
colesy
  172 182 197 E61 530D
I haven’t fitted one yet but I’m going to when I finally get my engine back together. Probably wouldn’t have this issue if I’d had this fitted!
M.C..
I’ve currently got my engine in bits and noticed a bit of damage on the crank pulley and casting so it got me looking I got lucky so will probably be buying this
JamesBryan
I had the genuine RS one from a MK3 cup racer fitted on mine, with some slight modification.
No one was making them for MK2 at the time.
Definitely worth doing I'd say, you never know if it'll save the engine one day.
MLB
How easy are these to fit? Any downsides?
Mine is going to Birchdown next week, might see if they can fit it for me if it's just a simple bolt on job.
PerthRS
  Clio 182 CUP
Got a PMS lower cambelt cover nearly 2 years ago. Also got the lower cambelt sprocket with the intigrated key to go with it.
Both still waiting to be installed :LOL:
Felt its definetly worth the extra security. Especially since the F4R is a needle in a haystack in Aus.
*From memory the APMotorsport unit needs to be motified to fit the Clio2 block.
The PMS plate that suits the Clio2 is the smaller one out the sample images shown on their website.
mumpy
  Clio II RS 172
Easy to fit if they are doing belts, I think to fit it afterwards you would need to redo the aux belt entirely
  • Like
Reactions: MLB
Matt Cup
  Leon Cupra
Thinking of getting one of these for mine. Looks like I need to renew the crank pulley anyway at some point as the rubber is perishing. Would it be worthwhile getting the keyed crank pulley or is it a waste of time on a standard engine?
JamesBryan
Yeah the APM one is the genuine Renault Sport item, the same one i had.
It's made from stainless.
