Trophy #199
neil a
I stuck a few pictures up in my other thread , but as this one is a clio so thought I would give it’s own post in here.
After selling trophy #57 around 5 years ago, just before the big price hike I thought I would never have another due to the cost now.
I originally set out to look for a 172 cup to have as a long term resto, I was talking to Stu from Renomotive and well one thing led to another and I ended up buying his Trophy.
It’s a well used car that’s lived a life 😂 including light front end damage when it was only a couple of years old.
Renomotive had looked after the car for the previous owner before buying it. It was then used for daily use and a Nürburgring trip, it has had a lot of mechanical work but cosmetically it needs a full repaint ideally.
Before picking it up from Stu , I had Sponge from on here to give the car a full cut to try and bring it back to red as the car was pink.
He worked his magic and made the car useable again until I look at paint next year.
The passenger wing and door had bad previous paint which couldn’t really be saved , so a replacement door and wing was soured and fitted this week.
Inside is fairly tidy bar a well worn Sabelt wheel, that I’m going to attempt to save.
I’ve also never liked the basic trophy rear bench so have fitted a half leather one with headrests.
You can see how far off the previously painted door was it sort of faded from dark red to trophy red.
neil a
Wheel re fitted along with a BMS shifter.
Just new dash trim strips to go and the interior is how I want it.
The only issue I have is a SERV light on the dash I’m guessing this is cause it’s had a screen fitted in the past with no auto wiper sensor. I’m unsure if this can be coded out to clear the light.
Brigsy
  T.Turbo
No auto wipers on trophy. Povo as fook!
Soon find out what serv light is on for with a quick scan with clip.
neil a
Ah that makes sense couldn’t mind if my last one had auto wipers or not.
I don’t have clip sadly , do you know if any other scanners will pull it.
Brigsy
  T.Turbo
Renolink will work. Maybe delphi. Worth asking if anybody local has clip, prob airbag related at a guess.
If your passing Middlesbrough at any point, give me a shout and i can plug it in.
neil a
I think I now know the issue after talking to Renomotive yesterday. The car got a low mileage engine for the a while ago along with 438 cams and mapped ecu/uch thus all came from a ff 182 so will need the auto wiper sensor coded out as will be looking for something that doesn’t exist.
neil a
So just bought this lot
Not got a clue how to use it, but hopefully will get to the bottom of the serv light or make a clio that will never run again :p
