What part do I need?
  Renault Clio 3RS200
I recently had some work done to my 3RS Clio, the car was pulling to the left and both front track rods were changed. But after the work has been done, the sterring felt so off. And after confirming by jacking up the car, there was some massive play in the ball joints!
I wanted to confirm what part I need and what I needed to get to fix it. Is it the Track Rod End? Or do I need to look at an issue with the brake disc mounting itself?
There's no way I can drive this car so I really do want to get it fixed! The brake discs are technically aftermarket, so I do hope that this hasn't been the cause of the problem.
