Sim Rigs - Let’s see yours
Matt Cup
  Iceberg 172 Cup
Ah didn’t realise you needed an adapter. Still might be something to look into.
  182 FF Inferno
Moza not compatible with ps5 unless you don't mind using an adaptor. £520 is a cracking price for the RS50.
As for a rig, if you can leave it setup I'd go for an extrusion type one (SIM lab, GT omega prime etc). They are quite industrial/ ugly. If you need something more aesthetically pleasing with the possibility of sliding it away behind sofa or in a cupboard, a lot of people like the Playseat Trophy.
Matt Cup
  Iceberg 172 Cup
Hang on with the RS50 you still need to stump up another £350 for the pedals? Do they not sell a bundle?
jenic
They don’t, but even so with the vouchers it comes to £520 with the basic pedal set, which is a load cell brake
  182 FF Inferno
I get the Logitech set coming in at £680? You must have some cracking vouchers!
That's ps/pc base, stock pedals, Xbox wheel hub and track rim as round is out of stock.
jenic
Two codes, one is HOLLOW and then sign up for the newsletter and they send you a 15% voucher code. Can use both.
It's £530, or do it in two transactions (rim and pedals separate) and strangely it's £520, just need two 15% codes.
Darren S
3D printed clips for the NLR GT Track frame.
Two sizes for the difference leg sections - clip on perfectly. No more shitty dangling wires or cable-ties attempting to keep it all neat.
Fredsta
  Clio rs 200 edc
Went for the knock-off 8Nm boost kit over the 5Nm default Fanatec offering. Half the price of the official item, but it works well. Glad I bought it.
I did the same as you but got it from aliexpress. Looks exactly the same and is cheaper, so long as you don't mind waiting longer for delivery. I agree though, it works well and no issues.
mace¬
  Clio
That's OK then. Just thought you'd thrown in the towel completely!
Its finding the time. Once I get into a decent routine I'll try to get at least an hour a day in at some point. Forza will be the catalyst I expect after holiday.
