Sim Rigs - Let’s see yours
Does anyone use a decent wireless keyboard with trackpad for their rig?
Any recommendations?
I did - and then switched back to a wired K&M with USB extension leads.
I was getting pissed off with the power saving of the wireless devices that sometimes wouldn't come out if sleep mode.
How do you handle that? Have a little table next to you for the mouse?
How about a wired keyboard with trackpad?
Yeah problem is the PC is the other side to where I would put the keyboard down, so the cable would reach across the rig
I used one of these for ages, it’s useless for gaming but if you just want something compact to be able to change settings/launch games etc then it’ll do the job
I echo the above, I had that exact one at my old job to control a computer that was on a big screen in the office and it worked great. Meant I didn't have to keep getting up from my desk to walk over to it.
I’ve still got a K400 I use for my Raspberry Pi. Been absolutely battered over the years and still works perfectly.
Does anyone have a buttkicker pro?
What is the ease to get it setup? Just a case of simhub and adjusting the levels?
Worth the money?
Does it ever go to a good sale price? Like ~£350 or is +£400 all you can hope for?
Worth the money?
I've only read mixed comments online and haven't actually tried one myself.
However, it seems to be a bit of a lottery with the integration of certain setups and software. If you have patience - go for it, if not I'd be a bit wary.
My cousin has one and rated it, it just adds to the immersion.
There are also haptic chest suits you could look into too.
Worth the money?
I haven't got the buttkicker pro, but i did opt for the trakracer option
I've only got it set up in a mono channel at the moment, but covers enough effects to add that little extra kick (gear shifts, traction loss etc)
Looks interesting, How do you mount it to the rig? Does it need the £55 tray for it to sit on, but does the tray not just rattle instead of the full effect going through the rig?
i've got the underseat mount, it clamps between the seat and the frame mounts. it also has a bit of padding between itself and the mount so that you don't get the rattling noises. it gives just the right amount of kick to get a feeling under your arse, and depending how you set it up in simhub dash, it makes a massive difference to the immersion.
Ordered. Just hoping I can get a good fit to the GTOmega Prime Lite now with the underseat plate.
Please don't judge :ROFLMAO:. This is my very temporary setup while I get the height and positions correct. I'm just bolting sections of ply into different locations so I know where I want everything when I make something better..
Well I did eventually build something slightly better but I didn't get around to it for 12+ months. The ultrawide is nice but I think I'm going to switch to triples (hopefully soon!)
The left/right spotter lights are incredibly useful too (you can just about see them under the monitor).
I also need to build something better for the keyboard/mouse but not sure how to tackle that yet.
Thats quite an upgrade 👍
At 85 years old, I have purchased playstation 5 pro, a disk drive, Fanatec dd wheel and pedals, and the Cockpit should be here in a few days. Never had anything like this before. Will be playing through my 85 inch tv. In my time, I have done Spa/Ring/Oulton/Angleasea Etc., so looking forward to this. I have told myself, it's an early Xmas present!. I will probably be asking a lot of daft questions, so I hope the idea lives up to the expectations.
Absolutely fantastic! Let us know how you get on, and I’m sure tonnes in here will be willing to help.
Now you just have to hope for a consistent enough electricity supply up there to be able to play it 😂
I’ve had it sat there for a week now waiting to be installed.
So did you put it between the frame itself and the sliding rails on top?
Also any loctite or anything?
between the seat rails and the main frame
i haven't loctited it as of yet and no discernable rattles
if you're using simhubdash i'll send over a copy of the profile i'm using for assetto/lmu and iracing
Thank you. Get it now. Will use sim hub but don’t play any of those games apart from AC Evo occasionally
Took me 11 hours, to put the wheel stand pro racing cockpit together. Yes I know, an 8 year old could do it in 30 minutes!!.It's a very strong piece of engineering, very well made. Hopefully fit pedals/wheel today.
Quick question, where have you mounted it? I've just got it next to the rig at the moment with the wires everywhere.
Game changer though, only used it for EA WRC 23 but the immersion with a bit of engine feeling and gear changes. Stil tweaking the settings for road impact, wheel slip etc but getting there.
Thought id share my setup. I started this earlier this year with a pc/fanatec setup. Ive since changed to simjack load cell pedals and an H patter shifter.
Mainly play raceroom And AC. Anyone know if there os online multiplayer racing for the clio 4 rs?
Had a Thrustmaster TH8A shifter delivered today, which I'll setup tomorrow.
Has anyone had any proper success in the past at dampening the CLANG noise of any shifter when selecting gears? I just know full well that I'll fit this tomorrow and it will start to annoy me with each gear selection banging through the NLR seat frame.
This was the main reason why I stopped using the Fanatec ClubSport shifter and I can't really understand why manufacturers don't cater for at least some form of rigid foam contact areas or o-ring padding. Something that just reduces the racket of gearchanges. None of us drive cars like that - so why simulate it? It's weird.
Tempted to see if even wrapping the shaft of the gearstick itself in some insulation tape, might reduce the overall noise.
edit - just seen this, seems a bit bodge-it DIY to me! :P
Added some tape to both the gearstick shaft and to the slots within the gate itself. Makes it MUCH quieter now - though with the steep angle of the gearstick itself for 7th and reverse, I can hardly select them through the build-up of tape.
Still, that's way better than the church-bell clang every time I select a gear. I've added the reverse onto a wheel button and anything that has a 7th gear uses flappy paddles anyway.
On the hunt for another NLR gear shifter mount for the GT Track frame now to move the switch box onto.
Started yesterday with the whole reinstall and setup of Content Manager, Simhub and the input configurations in the racing games that I downloaded. Finished it off with having several practice laps around Brands in an RX-7 with manual shifting - proper fun.
Anyone have any recommendations for open world tracks - ideally with traffic? I don't mind paying for quality ones and have membership to Overtake.gg already.
Cheers.
Back on the idea of a sim rig, it must be winter and I'm bored 🤣
Has anyone tried the Logitech RS50?
I think realistically options are RS50 or DD Pro, I ideally want PC/PS5 and Xbox compatibility and I don't think a T598 can offer all three.
I think the RS50 is the better base and the entry level pedals are better too, pricing is similar between the two. But the Fanatec has the way better eco system thinking to the future, and would probably sell easier if(when) I realise I never use the thing.
Can't comment directly on the RS50 as I haven't used it but reports are very good. I think you have to buy the base and wheel in different versions to cover all consoles and PC.
I run the T598- much maligned and there are/ have been many issues on reliability. Touch wood, mine is an early version but has been fine so far. I chose it as I already had Thrustmaster gear already (TLCM pedals, wheels, shifter) so it made economic sense. It was also cheap compared to Fanatec and Logitech.
If I had the budget/ didn't have any Thrustmaster stuff, I'd have probably chosen the RS50 only issue for me is lack of ecosystem. I think it's getting better with the McLaren tie up but I'd still nowhere near Fanatec/ Thrustmaster . I remember when they released the original G pro wheel, promises of accessories and extra wheels but nothing came of it.
As for resale, Fanatec would probably be easier to sell, but going by reviews, the Logitech performs better. And it's 8nm as standard without having to buy a booster.
Edit- you will need PC/ Playstation base and Xbox wheel hub to cover all bases on the RS50.
Yep, that's what I'm thinking too, it's better but fanatec is more sellable.
The RS50 actually works out cheaper if you buy it in parts rather than the bundle, which is weird, but allows you to buy the PS base and XB hub. They also have some pretty good voucher deals, which make the wheel/hub/base/pedal bundle about £520.
I'm researching rigs etc now, it's so much to buy all at once. I'm half wondering if I just buy a GT Omega DD-X stand and use it up to my desk with an office chair to get started.
