KTR Clio 2RS Induction Kit - New Version
Darren S
So, purchased this from K-Tec recently.
The build quality of the piping and fitment was really pretty good and help removed a lot of OEM airbox items and associated piping. No instructions came with it, but it's a few clips and a change in bracket. Hardly rocket science. The piping is actually a bit too long and will need a few inches removing - but I'll do that at some point in the near future.
Once fitted - even a little dab of the throttle sounded more 'gaspy' but nothing silly. Took it out for a drive and pootled about waiting to get the engine warm - no real difference in noise, but noticed that the acceleration was more smooth. That could have been a slight placebo effect, or more likely - the ITG panel filter previously fitted, hadn't been cleaned for a while.
Regardless - when accelerating harder, the noise was definitely louder. Significantly so. I had a Pipercross induction kit years ago fitted to my Punto GT and it sounded nothing like this. Yet push on and the sound gets really quite addictive in the most wonderfully chavvy/ASBO kind of way. Keeping the throttle planted from 4.5k upwards and it takes on a completely different V-TEC'ish scream. Really childish, but I love it - more so that you have control of when it makes a racket.
However..... The same build quality cannot be said of the Pipercross foam section, which is terrible. There is no metal or hard plastic collar on it to connect to the metal pipe. When tightened (even lightly) with the clip around it - the foam itself gets sandwiched between two hard, metal layers. The outcome to me anyway was pretty obvious - and within a week this had happened. The first pic being with the clip in situ and the next, once I had slackened it off to reveal the damage beneath it.
I've contacted both K-Tec and Pipercross about this. It's much more of a Pipercross problem as even if they sent me a warranty replacement, the result would be the same within a very short space of time.
I'll add updates to this as and when I get them if people are interested, but for now, I'm likely to put the OEM airbox back on to remove the risk of any foam parts being ingested by the engine.
ex-Chinese Dave
  172 Cup
I bet it sounded epic, Daz. I'm sure i've read that these filters are poorly made and bits come off easily. Can you fit a different filter to that inlet?
davo172
  TCR'd 172
How can they "design" what is just 2 90 deg bends and a bracket welded to it and be a few inches out 🤣🤣
Then never even test the thing before they sell it otherwise they would realise the issues before selling any.🙄
Louis
I Love Ed Sheeran
V2 is essentially the fatty induction kit.
If you can get your hands on the original with the og ramair filter these are far superior.
Louis
I Love Ed Sheeran
You don't happen to know the part number of that one do you? I noticed that there's a few Ramair cone filters even on Amazon.
Unfortunately not.
It was one of those that was never an official release AFAIK.
Noone could ever correlate it to an exact match from a supplier
Darren S
Bought the above - cheers!
Was keen on getting it here ASAP and Amazon were a little cheaper, so win-win.
Now for the faff in claiming some money back for that crappy filter!
Darren S
So, the Ramair filter arrived yesterday and I fitted it today.
From the outset, the manufacturing quality was WAY superior than the Pipercross effort. I particularly liked the small lip within the collar that stopped the 70mm induction pipe from sliding further into the cone filter itself.
I found it much easier to line it all up and position it with the battery out too.
Took and image of the state of the Pipercross filter when removed too - absolutely piss-poor design.
Thanks again to @Mr Trailer Man for the Ramair recommendation. Took it out for a little blat earlier and it sounded great. Cheers!
JamesBryan
Everything about the RamAir is better quality.
Them and ITG are really the only ones worth using.
Colz
  Clio 182
Im not the only one.. it happened to me as well.
Iv emailed K-tec and they are so say talking to there supplier.
